Old 05-31-2015, 09:51 AM
FFCub's Avatar
FFCub FFCub is offline
Default 682 won't stay running
Yesterday my dad bought a cub cadet 682. It will not stay running unless the choke is all the way out. Dose the carb need adjusted or is it another issue?
Old 05-31-2015, 11:19 AM
Sounds to me like the carb needs to be dissembled, cleaned and rebuilt. My guess is that it's pretty well plugged up inside.
Old 05-31-2015, 11:28 AM
I agree with Sam 100%
but you might first see if you have good fuel flow to the carb.
check in-tank shut off valve screen, line filter?-- if good flow to carb,
then as Sam says, remove carb and get the ferrin' critters out of it.
It is easily done, and is prolly the problem
Old 05-31-2015, 11:38 AM
FFCub's Avatar
It's running but backfires. Adjusted both the top and side needle valves to 1 and half turn off and it runs better but has to have choke about half open to stay running. What are the correct settings for the top and side srews ? seems to be running somewhat hot and still backfiring.
Old 05-31-2015, 11:45 AM
Carb needs cleaned/ rebuilt.
Old 05-31-2015, 11:46 AM
Everything you have said indicates a carb that is at least partially plugged. It's running lean that's why you think it's hot. Go to the tech section and down load the service manual for your engine. The info you need is in it.
Edit: Here is the link for the manual. http://www.onlycubcadets.net/forum/s...ead.php?t=4649
Old 05-31-2015, 11:50 AM
Open up the top needle an additional 1/2 turn (main jet) and see what it does, it sounds lean.
You could have a point gap problem too.
And how are the plugs?
good fuel?-- old? has it been setting?
if it is your lucky day and all the stars are aligned you might get the carb off and cleaned up with damaging a gasket (s)
A couple of gaskets and needle seat is maybe $12.00 or so.
Down load the free service manual on here in tech section,-- lots of what you gonna need now and later.
Edit: you guys type faster than me.
Old 05-31-2015, 11:53 AM
FFCub's Avatar
thanks for the info sorry about the double post.
