Old 06-24-2015, 01:26 PM
timbo2's Avatar
timbo2 timbo2 is offline
Default Anyone put a 60" Haban deck on a 2284?
It's not shown as an attachment on partstree. Looks like it may need a different belt for the larger PTO pulley on the 2284.
Thanks-
- Tim
Old 06-24-2015, 02:19 PM
jimbob200521's Avatar
Yep, they'll fit and work. If you wait a bit, Sam Mac will be along to verify this and give more info as he is the Cyclops man
-Ryan
Old 06-24-2015, 06:55 PM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
Parts tree shows a part number 325, 60 inch, deck on there. Don't know if it's a Haban or not.
Old 06-24-2015, 07:05 PM
timbo2's Avatar
Yeah that's a different 60" deck. I'm referring to the 374 deck-
Thanks though-
- Tim
Old 06-24-2015, 07:08 PM
Timbo
What deck are you putting on the 2284? Should be no big deal to find a belt for it. Cub had a 60" deck for the 2284. As long as you have the big pulley on the deck it should be what ever the factory calls for.
Old 06-24-2015, 07:35 PM
timbo2's Avatar
Sam,
I have the 374 deck that has been used on the 1872 and 2082 with the smaller pto pulleys on magnums. The 2284 pulley is bigger. So will that work or will the deck spin too fast? I figure a belt 1 or 2 inches longer should work but I'll try the current belt first, figure it may be too short though.
I aslo have a 54" GT deck that is made for the 2284. Just checking my options though.
Thanks.
- Tim
Old 06-24-2015, 07:39 PM
timbo2's Avatar
and when I say the pulley is bigger I'm referring to pulley diameter, NOT belt diameter. These are all 5/8's belt pulleys I believe
- Tim
Old 06-24-2015, 07:44 PM
No big deal, replace the center pulley, here is the part info
Cub Cadet 756-3057 Pulley, Center
After that this should fit but no guaranty, I just go to TSC and get the 3 closest sizes and use what fits best and return the others.
Cub Cadet 954-3051A (replaces 754-3051A) Belt, Mule Drive
