Old 09-03-2015, 05:24 PM
Sam Mac Sam Mac is online now
Default Words fail me on this mess
Why do I think drugs were part of the issue with this design.
http://limaohio.craigslist.org/grd/5170688965.html
"This is a mower/tractor I built a couple of months ago. It has a cub cadet 122 rear end and frame. And the extension frame is from a cub cadet 1225. The motor is a Wisconsin 4 cylinder engine that runs good. I had the mag rebuild and the starter rebuilt. Starts up good but may need a carb cleaning. Once it runs for a couple minutes it runs like a top. I had a drive shaft made for it and I did a lot of fabrication. Motor lowers and raises to tighten belt. Has a clutch mounted on the motor. Gas tank has a tiny hole at the top by the lid but it's not a big deal some just splashes out when you go over bumps. Both front axles steer together. Has 4 inch wheel spacers on the back, Ag tires and rear weights do not go with it. I have good turf tires I will put on the mower once sold. There is not another one like this anywhere"
Yep that is a pretty safe bet.
Old 09-03-2015, 05:26 PM
$2600 for that pos? It's hard to see on my phone but is the drive belt running in a figure 8?
Old 09-03-2015, 05:40 PM
On a positive note, I bet that tractor sounds good when it runs. Always liked the sound of those old V-4 Wisconsins running on a hay baler.
Old 09-03-2015, 05:41 PM
Sure looks like it is a figure 8, guess that's how he dealt with the rotation problem. Here's your sign.
Old 09-03-2015, 06:34 PM
Makes me wonder what he could do with a little guidance
Old 09-03-2015, 06:41 PM
He's got 4 steer wheels, I'd say there's plenty of guidance.
Old 09-03-2015, 07:13 PM
I too like the old Wisconsin engines, but that REALLY is the only thing I like about that old dog.
It reminds me a little bit of when Fred Flintstones car flips on its side at the drive-in when the girl puts the rack of ribs on it. Unless you never took it off the level ground, I don't know how you would ever keep it upright.
Old 09-03-2015, 09:33 PM
cadzag72 cadzag72 is offline
What ag tires? Those sure look like turfs to me!
Ian
Old 09-03-2015, 10:01 PM
john hall's Avatar
We ALMOST put a 4 cylinder Deere power unit off a pull type combine onto a 100 Cadet roller. But then we came to our senses. Actually acquired a combine to put the engine on and the rest of the parts to build the Cadet.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-04-2015, 08:27 AM
rocker582special's Avatar
rocker582special rocker582special is offline
I saw that tractor at a show in richwood Ohio. It's a pulling tractor for sure but I would never own it. Especially not for $2600.
