Old 07-19-2010, 09:20 AM
Mountain Heritage's Avatar
Default Briggs & Stratton Engines
Just wondering....have an 18hp single cylinder Briggs that is giving me issues. Has run perfect since I bought it new about 7 or 8 years ago and started acting up this year? It will run fine and then all of a sudden will start to spit and spudder and sometimes just shut down or sometimes will cough a bit and then keep running? If it does spit and die, I shove the clutch in and start it up again with no problem except it will back fire as it starts with a heck of a sounding backfire. So is this dirt in the gas/carb/fuel filter, or is there something electrical with it? It will do this if the mower is engaged or not. STRANGE!!!
Old 07-19-2010, 06:16 PM
lowlyfzlucky's Avatar
lowlyfzlucky lowlyfzlucky is offline
My "daily driver" mower had very similar symptoms. Bad coil. It's hard to test for this since the issue is inconsistent spark. Just my 2 cents.
Eric
1450 in progress..........
Old 07-19-2010, 06:17 PM
Oh ya, and that engine is a 16.5 HP Briggs.
Eric
Old 07-19-2010, 08:00 PM
Bad coil? Ummmm...dumb question - where would the coil be on an 18hp Briggs? I know this sounds stupid - wait a minute , it is a dumb question! Bear in mind this is only an engine that is about 7 or 8 years old - it isn't like 25 years old or anything. Is it likely to be hidden under the plastic crap sheilding on it? My lack of engine knowledge is showing through here BIG TIME! I see the solenoid, starter, oil filter, plug wire and spark plug.....so is it going to attached to other end of the spark plug burried under that engine casing?
Old 07-19-2010, 08:11 PM
You have to take off the shroud. Follow the other end of the spark plug wire down the yellow brick road and you will find it.
Eric
Old 07-19-2010, 08:25 PM
Ok, that is sort of what I thought - but I figured I had better ask. Look dumb asking, look even more dumb not asking and replacing something that isn't the correct thing!
