Old 11-28-2015, 01:29 PM
Default 56 crown vic
Getting some time to work on the crown vic. here's a pic of the new lower quarters fitted, still have to fit the rocker and then it will be time to weld.
Old 11-28-2015, 02:41 PM
Pic of the rocker fitted in place.
Old 11-28-2015, 03:11 PM
Up close pic of the seam. When it comes time to weld I will start by plug welding the big holes closed and then weld the seam solid, once the seam is welded I will remove the screws and weld the holes shut. It will probably take the better part of a day to weld this solid without warping it.
Old 11-28-2015, 03:31 PM
cubs-n-bxrs's Avatar
Tim great job. That is my favorite Ford.
Old 11-28-2015, 04:19 PM
How do you make the small holes Tim? With a punch? Or with a spot weld bit? (The ones with a center push pilot that look kind of like a hole saw.)
Old 11-28-2015, 04:30 PM
I have this tool that's a hole punch on one side and the other side steps the metal in so the 2 pieces of metal sit flush with each other.
Old 11-28-2015, 04:40 PM
Cool.
That tool is now on the list of tools I don't have, but want.
Old 11-28-2015, 04:43 PM
Why do you use screws instead of cleco's ?
Old 11-28-2015, 05:04 PM
because i have screws. i prefer screws because the panels don't always fit together perfect and the screw will draw the 2 pieces together vs having to hold the 2 pieces together while you put the cleco in.
Old 11-28-2015, 05:33 PM
OK, I've been happy using Cleco's on my race cars. That said the fit and finish was not all that critical.
