Old 12-06-2015, 11:43 AM
ford4150's Avatar
ford4150 ford4150 is offline
Default ISO 2 stroke ignition guru
Lots of talent here, so I'll give this a try.
1978 Honda Hobbit PA50II
magneto ignition with points, coil with external condenser
Problem: no spark
If anyone wants to play along, I'll post all my diagnostic info on here.
Any takers?
Old 12-06-2015, 11:46 AM
Go......I'll play.
Old 12-06-2015, 01:12 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Bring it on!
Plow blade
#2 Cart
QA36 snowthower
Old 12-06-2015, 01:40 PM
It's been 2 hours.... you got a question?
Old 12-06-2015, 01:50 PM
Maybe he checked the kill switch or the key
Old 12-06-2015, 02:50 PM
If he has a problem with a 3 stoke sinusoidal encapsulation valve causing the bi-directional sleeve valve to convolute the electro magnetic field to reverse polarity he can try inversing the vari-valve accumulator ball valve to restore retro firing of the after burner causing the directional reversing of the power piston.
That should rectify the platinum ferro deposit transfer.
Old 12-06-2015, 03:12 PM
Looks like maybe his interweb went down too.
Old 12-06-2015, 03:27 PM
ford4150's Avatar
Looks like some interest. Nice day out, yard work to be done.
I have a lot of info to post; might take me the rest of the afternoon to get it on here.
Start off with photos of the parts.
Old 12-06-2015, 03:35 PM
How about start with what you know/don't know. We all know what the parts look like....
Old 12-06-2015, 03:44 PM
ford4150's Avatar
OK. It will take a couple posts.
Stator and points:
Points are new Honda OEM, set at 0.014"
Resistance measurements for stator, measured with points open.
red-green 2.1 ohms
red-yellow 2.5 ohms
green-yellow 1.4 ohms
black/green 1.9 ohms
green-frame 0.2 ohms
