Old 07-21-2010, 11:25 PM
IHinIN IHinIN is offline
I've got the angle cylinder mounted to the front blade. It's 1.50" bore x 7" stroke. The front quick connects are mounted too. I need to plumb the quick connects to the valve and make a couple hoses for the cylinder and then I'll be able to try it out.
Old 07-22-2010, 08:05 AM
Awesome job, Adam! I've really enjoyed this thread!
Old 07-27-2010, 11:48 AM
mrcubcadet's Avatar
Great job on your hydraulics!!! I can't wait to see more pictures.....
Old 08-19-2010, 09:58 PM
Got the rest of the hydraulics plumbed. The power angle works great. I just need to anchor the lines in a few places and then take them off and shoot some paint on them. I added a set of quick connects on the rear too.
Old 08-19-2010, 10:32 PM
Nice job, Adam!
Old 08-20-2010, 11:23 PM
mrcubcadet's Avatar
Your hydraulics, and everything else you have made are GREAT! Keep up the great work!
-105___ Tiller
Old 08-20-2010, 11:49 PM
Thanks everyone.
Old 08-21-2010, 12:09 AM
mrcubcadet's Avatar
Thanks everyone.
Well............I think you have completed this project, so isn't it time for some action pics?:biggrin2.gif:
-105___ Tiller
Old 08-21-2010, 08:25 PM
cadetfarmer cadetfarmer is offline
Default Kewlll!
IHinIN;
Your hydraulic installation looks great, better than factory.
I have been gathering parts to do something very similiar on my 100.
I have a question, how did you adjust the pressure on the power steerin pump?
Beautiful work, true craftsmanship;
CadetFarmer
Old 08-22-2010, 10:33 PM
Thanks cadetfarmer.
I adjusted the pressure by shimming the relief valve in the pump. The shims go between the end cap and piston housing. Adding more shims reduces the pressure while removing shims increases pressure. The relief valve is located behind the fitting that the pressure line screws into.
