Old 01-26-2016, 04:57 PM
curtm's Avatar
curtm curtm is offline
Default Rebuilt 3185, 46" berco blower
Machine was completely tore down, repainted, new seat skin, new hyd lever bushings, also painted Quick attachment, 46" blade and rebuilt the blower, also have 50"and 60" decks for it, it has the original 18hp briggs in it, but have a 22hp kohler if i ever need
think it looks okay
i hear the pto runs at 2000rpm, blower works fine but may need to speed up with sprocket change, we'll see
not sure why pics are rotated, tried 4 times to correct ????
Old 01-26-2016, 05:07 PM
OldSkull's Avatar
OldSkull OldSkull is offline
corrections done..... Nice machine
Gilles.
1963 100 (red)/in storage
Old 01-26-2016, 05:35 PM
Nice rig!
Old 01-26-2016, 06:06 PM
curtm's Avatar
hey how did you do that with the pics ???
also had to fab new adapter for the quick change for the blower and fab new pto shaft
have a question, seems to jerk a little when lifting blower or blade, oil level is okay, not sure what is causing that ???
Another question, What hydro oil do i use, read on here somewhere to use Rotella 15w40 true or not ????
also is it true PTO runs at 2000 rpm ????
i work and rebuild a lot of different mowers, the deck you see on the lift is off a mod# 2016 ingersoll, also in the process of rebiuilding a 970 Husqvarna articulated, just sold a Duetz allis 1618 with blower, mower and blade, but this cadet is my favorite with the pedal shift, works good
Old 01-26-2016, 08:34 PM
Curtm, nice snow removal unit you have there.
The jerking lift could be the wrong oil, sticking spool valve, or the cylinder.
The correct oil to run is Cub's "Drive System Plus". It's kinda pricey but it's correct and is synthetic.
I use a contact tachometer on my machines and when the engine is at 3600 RPM the PTO should be spinning at 2000 RPM.
Here are some free manuals if you don't have one yet.
http://www.mymowerparts.com/pdf/Cub-...epair-Manuals/
