Old 02-03-2016, 08:20 AM
Oak Oak is online now
Mike, is your indicator light wired in parallel or series? If not in parallel it will choke the voltage down and cause your problem.
Old 02-03-2016, 08:41 AM
Clipped to the positive terminal and touched it on the red wire to the first light, and we had LIGHT! Wow, them suckers are bright! So now I get to figure out what it is that is causing the problem.
Glad to hear you know where to start looking.
You have a "high resistance" connection somewhere.
Old 02-03-2016, 02:50 PM
Your wiring should be on an order something like this....
Old 02-03-2016, 06:22 PM
Mountain Heritage's Avatar
WooHoo!!!!
That solved the problem! Changed the way the indicator light was wired and two of the connections and we have LIGHT in all four corners like it should be.
Thank you for all the help guys!
Roland, I'd like to suggest you do a little blurb in the how to section on how to diagnose LED lighting issues for those people like me who do not know. Between what you and the others advised to check for as well as your wiring diagrams - bid help and easy to understand. I appreciate it. Pictures to follow once I downsize them. Now onto other jobs! Like cleaning up my bench!
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 02-03-2016, 06:47 PM
I didn't focus in on the indicator (or pilot) light until I re-read the posts.
Glad to hear all is good now.
Old 02-03-2016, 08:26 PM
Here are pictures....
Bench that needs attention
wiring all fastened up and ready for the doors. I left the indicator light in, otherwise I would have a blank hole in the steel mounting plate. Figured it looked better with the light in the hole.
more wiring
Mike
Ontario, Canada
Beware of the Wife
