Old 05-16-2016, 05:03 PM
BeerHunter BeerHunter is offline
Default SLTX 1054 mower deck idler arm..how free should it be?
I thought it might be the PTO until I read in these forums about the idler spool. I checked mine out and the pivot arm was frozen solid. I had to use a socket and snipe to free it (after removing the spring) and have been pouring the penetrating oil to it and working it back and forth to the point I can now move it back and forth by hand fairly easily.
Question is how loose should it be? There's still a fair bit of resistance but should it flop around loosely or is the resistance normal?
Txs
Old 05-16-2016, 11:19 PM
Berwil's Avatar
Berwil Berwil is offline
I say if it's bolted in place with no spring or belt, it should swing down on its own when you stand the deck on end. If it were mine, I would unbolt it, clean the rust off the pivot and inside of the arm, grease the pivot, reinstall and call it good.
Bill
Old 05-16-2016, 11:59 PM
Txs - that's what I needed to know. I'll try unbolting the thing and do what you suggested.
Old 05-17-2016, 07:58 AM
Once you get it cleaned up, you will find it is a loose fit.
