Old 06-09-2016, 12:52 PM
Dostuki Dostuki is offline
Default Bad vibration on 1450
It started out as a light rattle about the last 2 or 3 times mowing. Now it is a full out vibration that shakes the whole tractor. The motor mounts were replaced a few years ago, and I've pulled the inspection covers off and can't see where anything is loose or out of adjustment.
It starts easy and does not smoke. I'm guessing it must be something internal in the motor, but I am not sure where to start. As it is now, I am not comfortable running the tractor anymore.
Any help would be greatly appreciated.
Old 06-09-2016, 01:17 PM
Did you confirm all the engine mounting hardware is tight? The oil pan bolts like to loosen and fall out.
Old 06-09-2016, 01:22 PM
Terry C's Avatar
Terry C Terry C is offline
Driveshaft running true?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-09-2016, 03:16 PM
There are WAY too many things to check on a Quiet Line before assuming that something is wrong inside the engine.
I would start by (as mentioned) checking the oil pan bolts and motor mounts then the front pto (just because you're already there) then the drive line.
If it's as bad as you say, it shouldn't be hard to find, but you're probably not gonna find it without getting your hands dirty.
Old 06-09-2016, 06:50 PM
twoton twoton is offline
.....then the front pto.....
Yosemite Sam, Are you suggesting that this could be the source of the vibration?
Old 06-09-2016, 09:00 PM
bocephus1991's Avatar
Does your 1450 have a clutch disconnect?
Brian
Old 06-09-2016, 10:34 PM
Bob95065 Bob95065 is offline
When you replaced the motor mounts did you do the engine cradle mod? If not the bolts probably backed out.
Check your rag joints front and rear too. There is a self-centering bushing at either end of the driveshaft that could be the culprit too but not likely. Pull the tunnel cover and see if the driveshaft is spinning true.
Old 06-12-2016, 01:50 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
A what??
1- 1200 in pieces
1- 1864 in pieces
Old 06-12-2016, 08:29 AM
Originally Posted by Rescue11 View Post
A what??
NOS 428 Cold Start Disconnect Clutch Kit PN/ 650-660 759-3534 or 190-428-100
Fits 682 782 784 1710 1711 1712 1810 1811 1812 and others depending on serial number
http://ccspecialties.org/clutch_driveline_rearend.html
Old 06-12-2016, 09:51 AM
Not that one,basically the disconnect on a 1450 is adding a gear drive clutch to a hydro.
Up to 534 and counting...
