Old 09-10-2016, 03:46 PM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Default Transmission on Cub 102
Is the transmission and rear end all one unit on the 102?
I had to drain the Trans fluid to change the Pinion, and it was as thick as honey, also pulled the lower plug on the differential and drained whatever I could.
I would hate to go through all this work and not ask this stupid question rather than find out the hard way.
I also happen to notice that Traveller Universal Tractor Trans/Hydraulic Fluid is on sale at Tractor Supply $11.99 per 2 gallon container.
Old 09-10-2016, 04:30 PM
Yes it's all the same cavity, the traveller fluid will be fine
Old 09-10-2016, 04:44 PM
Tom4981's Avatar
Great....Thank You very much....
