Old 09-15-2016, 04:35 PM
jtexx jtexx is offline
Default Electrical issues with LT2180
Well this rat race started when I decided to buy a new PTO clutch since my blades were barely spinning up and came to a near stand still when they hit grass. After receiving the clutch they recommended checking voltage before installing. I checked the voltage coming out of stator plug(that goes to regulator) and was getting 29 volts AC. Checking DC voltage out of regulator I was getting nothing. SOOO 3 voltage regulators later, thinking I was getting a bad one from a cheap distributor on amazon I'm still getting nothing. Question! When I initially checked AC voltage out of stator I hooked positive lead to one prong of stator plug and negative lead to the the second prong of stator plug(2 prong plug) and was receiving 29 volts. I later read that you have to check each prong individually with the negative lead grounded to the engine or somewhere besides the battery. When I do this I get nothing out of stator. If this is the correct test then I have a bad stator. Just want to make sure this is correct. Why am I getting 29 volts when hooked to both prongs at the same time?? Been working on this 2 weeks and tired of messing with it.. Looks like to change stator is a major job with the motor(18HP Briggs Vanguard) sitting backwards and the drive shaft coming out of it..?? May just park it and get a new mower next spring. She's been a good one for 12 years.. Thanks for your help!!!!
Old 09-15-2016, 05:00 PM
From the data I have seen, the Regulator should be a 845907.
With that in mind, you should be in the neighborhood of +/- 30 VAC across the Yellow Stator Wires.
From chassis ground ( or regulator case) to the Red Wire, you should have +/- 14.5 VDC.
This is based on (a) the correct V/R, (b) the V/R is working correctly, (c) the tractor is wired correctly, and (d) the engine is running at WOT (or 3600 RPM's).
Old 09-17-2016, 08:45 AM
Sounds funny that you have had so many bad regulators but for what it's worth I'm not impressed with Vanguard regulators. Now when I get a bad one I convert it to a Kohler regulator. If you PM me your e-mail address I'll send you a how to. This is the Kohler part # I've been using 41-403-10-S regulator
If you Google "Kohler 41-403-10-S" you'll find them relatively cheap on Amazon.
