Old 10-09-2016, 07:08 AM
The stub on the driveshaft does fit in the rear coupler for sure. Looks to me like the rear of the shaft is hanging free, supported by the SOLID front coupler with a pin through it. If you force them together, you're going to bind up everything.
Old 10-09-2016, 09:39 AM
slim5555 slim5555 is offline
I installed a new coupler at the engine and a new driveshaft. it has very little wobble at the hyd end of shaft. With the shaft centered on it's wobble (vertically) The center of the shaft to the center of the hyd shaft is about 7/16
off center. I'am going to remove the motor today and take the oil pan off, It should have a part number embossed on it. I was told that Kohler made oil pans that would make a difference in height.(For other equipment). Or maybe
Kohler changed the block on the k301's b/4 retiring this model.
Old 10-09-2016, 10:36 AM
I don't know what's wrong with your drive line alignment but I'd fix it before I put the tractor in service. If you don't, you'll likely wind up with another drive line destroyed.
Old 10-09-2016, 10:42 AM
before you take it apart you should post some pics of the front of the driveshaft and where the engine mounts to the frame, it might help give us a better idea of where the problem is.
Old 10-09-2016, 11:01 AM
Look at this page. Could be your problem?
https://www.partstree.com/parts/kohl...an-0209015952/
If you change pans, make sure your dipper doesn't hit the new oil pan.
Old 10-09-2016, 11:12 AM
Driveshaft looks to be too short,The pin does go in the hole.You can try loosening all 8 bolts on the tranny and see if you can move it up for better alignment.And yes,there are 8.
Up to 534 and counting...
Old 10-09-2016, 05:50 PM
OK, I loosened all 8 Bolts at the trany and only could get about .050 difference in height, And in the pic's of driveshaft the motor is not Bolted down or the end would be in the coupler. So I removed the motor again, Took the oil pan off and the number embossed on it is 47 475 01. I could not find any info on that number. maybe one of you so helpful people would have a oil pan that you could measure the thickness of the pan were the motor mount ????
Old 10-09-2016, 07:59 PM
mortten mortten is offline
The bosses on my K301 out of my 122 are 1 1/16", maybe 1/32" more. My eyes and the light weren't good. I know it was less than 1 1/8".
Doug
QA-36A
42" blade
Old 10-10-2016, 05:07 PM
Thanks, my oil pan also is 1.062, I am stumped the only thing left to do is to shim the motor in front to lineup with hyd unit and use the modified shaft fix with u-joint and flex plate at motor, It's the only way to insure proper alignment. I work in a machine shop so it will be a piece of cake.( I hope)
Old 10-10-2016, 05:26 PM
Lets see a picture of where the shaft attaches to the engine.
Tags
109, driveline problem
