Old 11-19-2016, 11:29 PM
rlneyhard rlneyhard is offline
Well just bought a 16hp Briggs V-Twin engine out of a cub 1641. I hope I made a good buy since its about a 2hr drive away.
Old 11-20-2016, 08:56 AM
ironman's Avatar
ironman ironman is offline
If it's not too late, here's an ad for a Kohler M20 in western Pa.
http://youngstown.craigslist.org/grd/5827915849.html
Old 11-20-2016, 09:16 AM
Thanks, but I'm in SEPA picked this one up on eBay and am heading to the Poconos to pick this up this afternoon.
Old 11-20-2016, 10:45 AM
If it's out of a 1641, try to get the plate that the engine bolts to along with the complete drive shaft and muffler.
Old 11-20-2016, 11:10 AM
How about the ignition switch too?
Old 11-20-2016, 11:14 AM
Shouldn't need the switch. The Briggs ignition was magneto just like the Vanguard he's getting.
I don't know why he would need the driveshaft unless just to sell or save for future projects. 582 is gear drive.... that shaft isn't going to work with the clutch.
Old 11-20-2016, 11:24 AM
Just curious.... question for the OP:
You said this needs to be a simple install. There's quite a bit of difference in length between the old Briggs and the Vanguard. You do realize this isn't going to just bolt up right? Your probably going to have to make a new driveshaft.
Old 01-27-2017, 10:50 AM
I wanted to thank everyone here for there help! Sorry for the hiatus, right after picking up the Vanguard engine everyone in my house got really sick and then I got busy at work.
So long story short. I was able to get the Vanguard engine installed in my 582 using a 3 pin drive plate that has the alignment bearing installed. Along with that I purchased an adapter plate that also made-up the difference in length so the front PTO lines up. (I can take some pictures if there is an interest)
The wiring was pretty straight forward (except everything is one the wrong side) with the exception of the fuel solenoid (just learned what that was after trying to start the new engine with no success) The choke cable was long enough but the throttle cable was way too short (hopefully will get a longer one today).
Thank you again for all your help on this project! I learned more about my Cub than I thought I would ever need to know.
Old 04-18-2017, 03:24 PM
Forgot to post a quick clip of my 582 shortly before getting some snow to plow. https://www.youtube.com/watch?v=uwaF...8&spfreload=10
Since the video I replaced the plugs and now you can't stop her!
Thanks everyone!
Tags
582, engine, engine swap
