Old 05-17-2009, 07:35 PM
jlincoln jlincoln is offline
Default 1604 won't start no spark
I went out and started my cub 1604 (Briggs & Stratton 16hp) it ran fine, then when I went to restart it later it did not start and I pulled the spark plug off and I saw that I was not getting a spark.
I replaced my voltage regulator last year, as I was getting an intermittent starting issue last year and that took care of it. Could it be that again?
If someone could point me in a systematic system of troubleshooting this problem I would be appreciative.
Safety switches are all bypassed.
Thank you,
Josh
Old 05-17-2009, 08:00 PM
It could be the ignition coil...those tend to go bad.
Old 05-18-2009, 01:24 AM
murphycc
Guest
Posts: n/a
http://www.mytractorforum.com/showthread.php?t=82267
I guess he didn't believe me either.
Scott
Old 05-18-2009, 07:54 AM
Josh:
The 1604 has a Motor that has a Magneto Ignition.
Here is a Wiring Diagram.
In order for the motor to start, the yellow wire(s) from either the Ignition Switch and/or Seat Relay have to be OPEN (nothing going to ground).
I would suggest either disconnecting the Yellow Wire going to the motor (or cutting it) and see if it starts up. If it does, then you have:
* A bad Ignition Switch
* A bad Seat Relay
* Some bad wiring along the Yellow Wires
Once the testing is done, you will either have to connect or repair the yellow wire back to the way it was.
Old 05-20-2009, 08:30 AM
Not at all Scott, I appreciate all the input.
I just posted on both sites that is all. Didn't know if I would get any responses.
I am greatly appreciative. Now all I need is some time off to work on it.
Josh
Old 05-20-2009, 11:32 PM
murphycc
Guest
Posts: n/a
Josh
just screwin with ya, I knew you'd be back around.
We do lack a little humor and sacrasm around here.
Scott
Old 05-21-2009, 12:15 AM
JMD JMD is offline
Smile Scott
Dat the truth
Old 06-28-2009, 02:22 PM
dwcphoto dwcphoto is offline
Default Model 1604 photo?
Hi Guys,
There's a model 1604, 18 hp for sale, says with a 68" deck. I can't find any photos of a 1604 and it's a drive to go see it. Can you help with information on these tractors? When were they built, are they a good model tractor? Thank you, d
Old 06-28-2009, 03:46 PM
dwcphoto-
I don't think whoever listed the ad knows what he's talking about. A 1604 has a 16 hp Briggs & Stratton twin cylinder engine, which is alright, but has a really dumb carb and is kinda cheap compared to the Kohlers in my opinion. Parts are fairly cheap for the motor. The deck would be a 44" or 50" deck most likely...there is no 68" deck. I'm guessing it's a 50" and the owner measured the overall width of the deck.
It would have been built roughly between 1987 and 1989. The rearend is also on the cheap side compared to other gear drive Cub Cadets...the 1604 was built to compete with lower-priced tractors. It's not as tough as a 1606 or 1806 which both had better rearends. If I were you, I'd wait around for something a little better. It'll cut your grass just fine, but that's about it.
Seeing that you're in Pennsylvania, there's a ton of Cub Cadets there. There are better tractors out there.
Old 06-28-2009, 06:58 PM
Default 1604
Thank you for your insight. I've been on a Wheel Horse for many years, so I have a lot to learn about the cubs.
What about the lowboys. Are they a good tractor? d
