Old 03-23-2017, 08:44 PM
DieselDoctor's Avatar
Default Filling rear axle
Has anyone come up with a clean way of filling a hydro rear axle that fills thru the dipstick tube? If you fill too quickly it traps the displaced air until it burps blowing oil all over. Last one I did, I used an old squeeze bottle from a liter of 90W gear oil. I was able to force Hytrans in and then allow the air to escape back into the bottle, but it still created a big mess. I'd be interested in hearing how others do this.
Old 03-23-2017, 09:41 PM
john hall's Avatar
Some guys run a small rubber line (maybe 2 cycle fuel line or something similar--as big as you can) through the funnel into the rear maybe a couple inches deep--helps if it was coiled up so it will try to curl up and out of the way of the stream of oil. This does a good job of letting air out. Also seen a pipe union (can't think of the correct term) welded to the rear cover plate kind of high up. This is the kind of "improvement" folks do when they have the back cover off for work or to completely clean out the inside of the rear housing.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-23-2017, 09:50 PM
dale c. dale c. is offline
a piece of 3/16 brake line up through the funnel to let the air out but it's still slow going a real [PITA]
Old 03-23-2017, 09:59 PM
Dirty Steve's Avatar
I installed a vent. Got the idea from Sam Mac.
Old 03-23-2017, 10:05 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
The vent trick works very well! I have also done it up high like john said in the rear cover on the cast rears. That works too!
Jay
Proud owner of the following:
Old 03-23-2017, 10:15 PM
Removing the one of the bolts that hold the trans to the frame works also.
Old 03-23-2017, 10:24 PM
You truly are the Master of Lew.
Old 03-23-2017, 10:43 PM
Thanks for all the great suggestions. For now taking the bolt out sounds like the best bet. I plan to do a refresh on the entire tractor at some point later this year and will drill and tap for a vent when I have the axle out.
Old 03-23-2017, 10:49 PM
jaynjeep's Avatar
I did the bolt trick once on my 1782... but had to put it back when it got near full cause it started pouring my fresh HYTRAN out!!
Jay
Old 03-24-2017, 03:36 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
When I put fluid in my 1863 earlier this week I took some 3/16 id vinyl tubing, drilled 2 holes in the lid that fit the tubing and set the 2 gallon jug on the fender. The tube on the left is long enough to go from the bottom of the jug to the dipstick tube. The tube on the right is only about 5 inches long, it vents the jug and I blew in it to get the fluid started siphoning. The holes are sized to make the tubing fit tight. It took most of the day for it to siphon into the trans but I had other stuff to do anyway. There was about an inch left in the bottom of the jug because the tubing curled up some. I put it in with a small funnel but at least I didn't have to do the whole jug that way. I threw the jug away or I would set it up and make a better picture.
Cannon
