Old 05-17-2017, 06:47 AM
quadguy213 quadguy213 is offline
Default #1 Tiller pulleys
hey guys, New here ive been a reader / lurker for awhile when ive needed help working on my 128 and 149. finally went and joined.
So I have a 149 and a #1 tiller with extensions i bought a couple years ago. Someone welded the large pulley on top around for some reason at some point in time (assuming they tried to remove it without puller and broke it) it was working but the pulley had a wobble. Well the other day i was tilling the garden it ended up splitting the smaller pulley in half. Question is where can i find these 2 pulleys? Ive searched ebay and that without much luck. Are there replacements out there for these? Part # ? Anyone have a good used set they would sell.
Any help would be much appreciated. Hoping to have the garden in before end of the month.
Thanks
Old 05-17-2017, 07:50 AM
sir_lancealot sir_lancealot is offline
See the thread below. Follow Sam Mac's link and you should be able to find the pulleys you seek. Just take measurements of the ones you have and order accordingly. I know for sure the large pulley can be found there. If your pulleys are tore up too much, I can measure the ones on my #2 tiller when I get home and let you know what size you should look for.
http://www.onlycubcadets.net/forum/s...ad.php?t=47692
Old 05-17-2017, 08:04 AM
thank you for the link. I did a search but didnt see that thread. I should be able to measure the bigger pulley, the small one is pretty trashed but ill try come up with a measurement.
Do you know the bore size off hand?
Old 05-17-2017, 08:20 AM
Seems like it might be 3/4", but I can't remember for sure.
Old 05-17-2017, 08:14 PM
thanks, im going to try and work on it this weekend and measure them. I feel better knowing there are replacement pulleys. A couple guys locally basically told me i was SOL
Old 05-17-2017, 08:30 PM
We don't give up that easily around here
Old 05-18-2017, 06:56 AM
Bores ae 3/4" on both gear box pulleys as well as the big cast iron one. Jeff can make new shafts for the gear box if needed as well.
Old 05-18-2017, 08:12 AM
i think shafts are ok. As least they look like it from what i can see. Ill find out this weekend.
Old 05-18-2017, 08:50 AM
Just make sure they are not bent is all.
Old 06-01-2017, 08:22 PM
sir_lancealot if you get a chance can you send me a measurement on the small pulley? That way im sure to get the right size. no rush whenever you get time. My pulley is pretty warped and split clean in half all the way around, came off in 2 peices.
Thanks
