Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Rear Engine Rider & ZTR (RER)
Old 06-10-2017, 08:20 AM
mabbgordon mabbgordon is offline
Default ZTR runs, but bogs down
Hello all,
I have to date changed spark plugs, air filter, treated new fuel, changed oil, cleaned carb. Can not get mower to run under load for more than 5 minutes unless you pull choke and stop pto for a few minutes, then runs fine for a few more minutes before acting up again.Any suggestions would be greatly appreciated
Old 06-10-2017, 08:23 AM
It is a RTZ 50 KW, with a 23 hp Kawasaki engine
Old 06-10-2017, 08:25 AM
It would be nice to know what you are working on, but as a general response
it sounds like you have a fuel issue so pursue that by checking your filter, Gas in the tank?
dirt in the carb or is it fool injected?
Old 06-10-2017, 08:44 AM
Rtz 50 zero turn 23 hp Kawasaki engine, runs fine without pto pulled?
Old 06-12-2017, 06:07 AM
Leadslingingdaddy's Avatar
Have you checked the valve lash??? How many hours?? Is it a FBV 621???
Old 06-13-2017, 10:27 AM
Ended up being the fuel pump
