Closed Thread
Old 06-24-2017, 12:12 PM
Nailhead Nailhead is offline
Ryan, gas will boil. It does so at a much lower temp than water. Pretty unsafe really....Lots of vapors.
And, if you leave a full, sealed gas can in the sun, it will flash boil when you remove the lid too quickly, shooting a stream of gas surprisingly high in the air.
1965 122 with no bells or whistles, other than a spiffy restored 42" CI deck.
Old 06-24-2017, 12:38 PM
sir_lancealot sir_lancealot is offline
I would go back with the sediment bowl, but keep the rubber hose. It's much better for the gravity-fed system. Pressured systems should use filters. And keep your tank full. Nothing wrong with doing that.
Old 06-26-2017, 10:56 AM
Thanks for all the advice, everyone.
I looked at the manual, and barring the cowl mount bolts and their inaccessibility, engine removal looks pretty straightforward, so my enthusiasm is returning.
We'll see how it goes. Thanks again.
Old 06-26-2017, 06:06 PM
REDDHOGG REDDHOGG is offline
Might look at the throttle shaft ,loose shaft can make a lean condition and over heating.
Old 06-27-2017, 10:55 AM
It's in good shape. I thoroughly inspected the carb when I rebuilt it, and the shaft bushings don't have what I would consider excessive play in them.
Thanks for the reminder-- I have to back that mixture screw out a half turn or so, although I set it to the specified initial setting, and I'm at about 5000' feet elevation. Maybe I'll make that change a last resort.
I'll check that shaft play, even so. Thank you.
Old 06-27-2017, 11:23 AM
The "specified initial setting" is just a starting point so that you can get the engine to run. The carb must be tuned to run with each individual engine. The book states this. I don't understand why people have such a hard time understanding that.
Gas will boil at lower temp at higher elevation.... but it still shouldn't be boiling in your tank.
Old 06-27-2017, 04:51 PM
Closing this thread before things get out of hand. The information has been given. The Original Poster can do as he see fit.
Closed Thread
