Old 08-24-2017, 08:59 AM
swoodward83 swoodward83 is offline
Default Need some help
I've got my grandfather's 70 model cub. I am trying to locate the serial number on it, or find out exact year it was made. I can't find the stamped serial number anywhere on the tractor, behind the rear tire I found a number stamped upside down into the actual frame. But there's no U in the middle for me to determine anything. I'm curious as to what year it was made. Any help to determine this would be appreciated. Thanks!
Old 08-24-2017, 09:01 AM
This is the 70 model I'm trying to find a serial number on. Can't find it anywhere.
Old 08-24-2017, 09:14 AM
The Serial Number for the 70/100 series are located here. There was NO serial number format the utilized the "U" back then. The serial number range was 65459 to 127160.
Old 08-24-2017, 09:20 AM
Ok thank u. I took pics of the number I found, so with that, how would I determine the year it was made?
Old 08-24-2017, 09:21 AM
This is the number I found.
Old 08-24-2017, 09:22 AM
So it's not the big number it's the small number on that plate?
Old 08-24-2017, 09:31 AM
the small number stamped into the square block is what your looking for.
the number you show in pix is a casting number
Old 08-24-2017, 09:34 AM
So this would be the serial number?
Thank you all for your help. I truly appreciate it
Old 08-24-2017, 09:39 AM
Now would this work also on the 122 model? Because I don't have a stamped plate and the spot where I found the s/n for the 70, the 122 doesn't have any numbers there.
