Old 12-18-2017, 08:16 PM
V30crewcab V30crewcab is offline
1864 is a nice machine.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 12-18-2017, 10:20 PM
DieselDoctor's Avatar
Welcome aboard Marko. There are many good options/combos available to do your chores. I'll agree that the 129, 149, 169 series Cubs are a great way to get into the hobby and you'll have a good durable tractor with many options. When you spot a tractor or implement you might be interested in let us know and we can help you decide if it is a good choice. You may find that you'll want more than one Cub, most of us have several. (at least!)
Old 12-19-2017, 12:14 AM
Originally Posted by Marko141 View Post
Might end up with an 1864, wheel weights, chains, 2 stage blower all ready to go. Still need to find a tiller though.
If you get an 1864, you cannot put an IH tiller on it unless it has a rear cat 0 3pt, and you buy an adapter to install it. Then, you will only be able to use the #2B tiller.
If it doesn't have 3pt, you will have to buy one, and an adapter OR buy the later model CCC built model 400 tiller.
Both these options are expensive.
I have designed an adapter for the aluminum rear ends so that you can run an IH tiller on them without having to have the cat 0 3pt and the adapter. But you will still have to install a sleeve hitch, and I do not know how that would work on an 1864, as I have not seen it done that I can recall.
I suggest looking for an IH built tractor or at least one with a CI rear end if you want to run a tiller.
Old 12-20-2017, 12:40 PM
Marko141's Avatar
Marko141 Marko141 is offline
Well I guess I'll have to do what you guys suggest and get 2 tractors then! One for tilling and one for the snow. I really do like the older look of those 129 and 149 tractors. And just like you guys have multiple cub cadets my interest was into golf carts before this. My big cart has a 23hp vanguard in it with billet pushrods, huge cam, bigger starter, and rev kit. She hits 45mph with a 25" tire and 7" double a arm lift. It's a remarkable machine.
Old 12-20-2017, 01:12 PM
Marko141's Avatar
This and put up a phot or 2, give it a test
Old 12-21-2017, 11:45 AM
RobSeidel RobSeidel is offline
Hello and welcome, Marko!
Old 12-21-2017, 08:21 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Well I guess I'll have to do what you guys suggest and get 2 tractors then! .
You'll fit right in here !!!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-22-2017, 09:38 AM
4 tractors is really the minimum. One for mowing, one for plowing, one for a snowblower and one for the tiller.
Old 12-22-2017, 09:48 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
You also need one for storing stuff on the hood and seat, one just to be in your way, one for "I don't have any immediate plans for it....but it was a deal" and one that leaks oil!
Queen Of The Quietlines!
Old 12-22-2017, 10:18 AM
jbrewer's Avatar
Then of course , one always needs a project to work on!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
