Old 01-06-2018, 10:28 AM
drcjv's Avatar
drcjv drcjv is offline
Default How would you do it
I have an original CCC grill emblem. One of the mounting studs is broken off the back. How would you repair it or replace the stud so it can be mounted.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 01-06-2018, 10:48 AM
Can you post up a pic of the backside of the emblem?
Old 01-06-2018, 10:58 AM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Drill it out and epoxy a small stud, could be an option.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 01-06-2018, 11:29 AM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Is it thick enough to drill it out a tap a few threads into it?
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 01-06-2018, 11:36 AM
Old 01-06-2018, 12:02 PM
drcjv's Avatar
Here are some pics. I have thought of these ideas but it is very thin about 1/8" on edges and half that in middle. Might have to make a separate backing plate.
2072 50" deck
Old 01-06-2018, 12:05 PM
drcjv's Avatar
I am still not sure if these belong on my supers. Other members have said their's had one others say no. Have seen pics both ways. Can't find on ant parts list.
2072 50" deck
Old 01-06-2018, 12:13 PM
I did mine by drilling a small hole through the emblem in the black part of the logo, then I used a small screw and nut and painted the head of the screw black so it blends in. Honestly, unless you know I did it you would never see it because it blends in so well.
Old 01-06-2018, 12:40 PM
Baccarat Baccarat is offline
Another possible option would be to drill a hole thru the emblem and press a flush mounting PEM stud in from the face side and then repaint the emblem. The drilled hole is specific to the stud thread size. McMaster Carr carries studs and if they don't have the size you want/need, S.W. Anderson does. That way if the emblem ever has to come off, you don't have to worry about repainting a screw head. PEM's are a permanent insert. We use them in our sheet metal manufacturing all the time. It's getting rare to see spec's that call out for weld studs and/or nuts anymore except for older design items that date back before the 70's or 80's.
Old 01-06-2018, 12:59 PM
drcjv's Avatar
The PEMS seem interesting but it seems like there are many types for different apts and materials not sure which to use. Also looks like you need proper tools to press in.
2072 50" deck
