Closed Thread
Old 04-17-2018, 08:50 PM
deernutz deernutz is offline
is that pieces of tweezers or nest. .lol. still trying how to get in there somehow.
TIME TO NUTT UP OR SHUTT UPP!!!!!
Old 04-17-2018, 10:07 PM
Take the engine out and remove the tins. Doesn't take long to get it out. Could have had it out by now....
Old 04-17-2018, 10:52 PM
What ^^^ said.
Old 04-18-2018, 09:51 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Otherwise if you decide to do it tornadoes way please be sure to take a video.
1- 1200 in pieces
1- 1864 in pieces
Old 04-19-2018, 07:12 AM
do it properly and remove the engine, then the shroud,
I second that. It will give a good opportunity to clean up the whole Flywheel Fan area, to ensure good air flow, to keep the engine cool. Check the "fin" area to make sure that is clean also.
Old 04-19-2018, 07:58 PM
Jonathan
Jonathan...you are a fuckin idiot!!!!!!!!!!!!! I am asking for help and u act like I am whining !!!!!!!!!!!!!FUCK YOU AND YOUR COMMENT!!!!!!!!!!!!!!! TO EVERYONE ELSE THANKS FOR THE HELP. GUYS LIKE U THINK UR SHIT DON'T STINK....HAVE A NICE DAY !!!!!!!!!!! ASSHOLE
Old 04-19-2018, 08:04 PM
I've seen Jon get people fired up before but you really take the cake. His comment wasn't even that bad as far as his comments go. If that's all it took to get you going you must be pretty sensitive. Also, language like that doesn't really fly around here.
Old 04-19-2018, 08:35 PM
passionate..........tractor was grand ma's from new. looking for help....Not much of a mechanic...Glad he fires up people...I have not been here since 2013...Now I remember why...
Old 04-19-2018, 08:45 PM
Ok. Well for grandma's sake you should pull the engine out and remove the tins so you can clean the fins out really well. That 16hp block will be expensive to replace if it gets ran hot and smokes the bore. I have a 16 here that had plugged fins and the bore got wore so bad from running hot that the block is junk. Where in PA are you located?
Old 04-19-2018, 09:18 PM
near harrisburg
Closed Thread
