Old 04-26-2018, 12:06 AM
1574trap 1574trap is offline
Default Haban mower deck
I have a Cub Cadet 2182 with a Haban type 60" mower deck. I need some information on where to buy mower deck bearing. I had info at one time of a place that sold these bearings in packs of 6-8 bearings but have lost info. I would appreciate a suppliers name you have used or would recommend.
Old 04-26-2018, 12:27 AM
Would I be correct in assuming, a supplier other than Cub Cadet...??
Old 04-26-2018, 12:42 AM
maybe. am trying to keep repaired a mower deck the cub cadet people no longer supply many parts ect. really should be asking if anyone out there has used other brands of deck spindles to keep these decks running. some of the cub cadet spindles may fit this deck -- just don't know.
Old 04-26-2018, 07:03 AM
I am also assuming that you have a 190-374-100 Mower Deck. According to the Cub Cadet Parts Lookup site, one would need (6) 759-3504 Ball Brg - 25MM x 52MM x 15MM Thk. ----> Repl by: 941-0301.
I would venture to say, that any Bearing Supply House could line you up with bearing(s) (25mm [bore] x 52mm [OD] x 15mm [thick], or take a bearing off, for a counter match up.
Old 04-26-2018, 07:43 AM
It is a 6205 double sealed bearing. Just remove the seal that faces the inside of the spindle and throw it away, clean the grease out of it and repack with the grease you use.
These will probably work fine and are cheap.
https://www.ebay.com/itm/Qty-10-6205...gAAOSwImRYDkvr
Old 04-26-2018, 10:57 AM
samckitt samckitt is offline
http://www.vxb.com/8-Bearing-6205-2R...d-p/kit487.htm
I have it noted that they are 25x52x15mm bearings.
________________________
Scot
Old 04-26-2018, 11:13 AM
thank you for the replys. did search and did not find nay of the sponsors selling bearings for the haban spindles. had bought a part from patton think it was mower blades.
Old 04-26-2018, 11:30 AM
Nobody will beat Ebay or VXB pricing.
Old 04-26-2018, 11:31 AM
thank you for the replies. did the ebay as it was the easy way ect. guess the bearings are china made. have never replaced bearings in these spindles and hope id do not need addition parts.
