Closed Thread
Old 05-19-2018, 07:35 AM
cooperino's Avatar
Default 126/1211 Mower decks question
So I looked high and low for a post about this. I might have missed it so I apologize if this has been answered already,
I picked up a new to me 126 last week. It now runs and cuts pretty good. it has a 42" fabricated deck. My 1211H has a GT46 deck that I had just finished rebuilding. The 126 deck like I said cuts okay but I feel like it will not have the power or flow to shoot grass into a bagger. My GT46 deck works very very well with bagger and I already have the parts for bagger. So, you all may already know my question. Has anyone put a MTD deck like mine on a 126? Will it fit? I can weld and fabricate if need be but was hoping there would not be too much alteration needed to do this. The lift system looks very similar but I have not measured anything yet.
Any help is appreciated
Thanks
Old 05-19-2018, 07:50 AM
This is your only route that I know of.
Old 05-19-2018, 08:06 AM
cooperino's Avatar
Default Im Okay with that!
Breaks out the torches and welder.... I guess the tape measure will be needed a little also.. Good rainy day to get started on it!
Old 05-19-2018, 11:21 AM
So, you have a 126 with a mower deck.... and a 1211 with a deck and a bagger. But you want to put the deck and bagger from the 1211 on the 126??
Maybe I'm missing something, but isn't it easier just to leave it alone and use it the way it already is??
Old 05-19-2018, 11:34 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Your 126 won't have the balls to pull a gt 46 high vacuum deck. I put one on my 1450, complete waste of time. Need 18 hp to pull it well. There is a lot to it. You would be better to find a 42"high vac deck from a 1440 and then mod the setup to your 126.
I love my baggers, but you need to match the hp to the deck. Been there, done that, bought the tee shirt. Lots of jacking around to get it right, adjusted properly to find out the engine doesn't have enough snort.
Similar, but you'd have more to deal with http://www.onlycubcadets.net/forum/s...ad.php?t=46362
1- 1200 in pieces
1- 1864 in pieces
Old 05-19-2018, 11:37 AM
cooperino's Avatar
J-Mach,
On the surface you might be correct. However I have plans for using the 1211 for other specific purposes other than cutting grass.
Old 05-19-2018, 11:42 AM
Trent, I'd just like to point out that a 1211 and a 126 have the same engine.... so if the 1211 will pull it, then the 126 will. Otherwise I agree.
Originally Posted by cooperino View Post
J-Mach,
It's J-Mech. With an "E".
Whatever you want to do. I try to keep things simple. If it was an easy swap, I'd say go for it..... but as Trent pointed out, it isn't an easy swap.
I personally hate baggers.....
I also hate mowing with a gear drive. Especially if you have a lot to mow around, or a small area that requires a lot of maneuvering. Also, keep on mind a NF doesn't steer as tight as the 82 style tractors.
Old 05-19-2018, 11:44 AM
cooperino's Avatar
My 1211 is a 12HP Magnum 12. Basically same as the K301A in my 126. On my 1211 the hydro begs for most of the power available, Hydros drives are less efficient than the gear box on my 126. I am failing to see your points in your response.
Old 05-19-2018, 12:01 PM
cooperino's Avatar
Default J-Mech
Hey, sorry for the typo there.
After looking at both units and doing some measuring, really not all that bad of a conversion. I will build a small "sub frame" to be fitted on top of the 46" deck. This will have hardware to make up the small span difference of the two different sub frames of units. The lift will still work the same way other than I might lose 1" "height of my subframe" from the top of my lift height. I never mow with it this high anyway and have no obstacles in yard that force me to raise deck to full height. If for some reason the 126 doesn't "have the balls" which it should since my 1211 12HP does. Its a simple change of pulley size to get desired power and torque ratio.
Thanks for the help guys
Old 05-19-2018, 12:16 PM
Keep us posted with pictures when you start working on it, I an curious to see what you do with the drive pulley.
Up to 534 and counting...
Closed Thread
