Old 07-29-2018, 06:06 PM
cnewell cnewell is offline
Question Help with Final Stages of Cub 100 Restoration
I’m finally getting close to finishing my first complete overhaul to a Cub 100 and I could use some expert advice. I’m installing a new wiring harness from Porch Electric and of course the original Starter/Generator, Voltage Regulator and battery were all separated from the tractor during the rebuild process. I’ve read a bunch of threads and various forums and I’m still a little confused as to what the proper procedure is for reconnecting and making sure things are polarized correctly, etc. Can one of you more experienced experts help me out so I don’t fry anything? Thank you!
Old 07-29-2018, 06:09 PM
cooperino's Avatar
Not sure about the brand harness you purchased but I thought most of them came labeled.
Old 07-29-2018, 06:25 PM
Hook up the harness and install the battery. As long as everything is hooked up correctly, it will polarize when you turn the key on the first time.
Old 07-29-2018, 06:26 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Link to wiring diagram:. https://www.onlycubcadets.net/forum/showthread.php?t=35
Plow blade
#2 Cart
QA36 snowthower
Old 07-30-2018, 07:43 AM
Default Thank you
Thank you for the quick replies and guidance. The wiring got harness came well labeled and looks pretty straight forward. My main concern was with the polarizing step after hooking up the battery again. Sounds like there isn’t any special process and that it all re-polarizes when you turn the key. If it’s really this easy it’s interesting how many discussion boards there are with this as a highly debated topic. I appreciate you all sharing your expertise!
Clint
Old 07-30-2018, 07:47 AM
Default Porch Electric LLC
Wiring harness is from Porch Electric, LLC. Looks like a great quality product, well labeled and the service was awesome. Placed the order and had the harness on my doorstep within a couple days. Highly recommended.
Old 07-30-2018, 08:00 AM
cooperino's Avatar
Clint
The forums you saw were likely talking about delco remy generators only. If the unit is used for starting and generator there is no need to polarize. It does it on its own as soon as you crank it. So if you ever work on a delco remy that is just a generator or will not use the crank function then yes. You need to polarize it. The process is extremely simple tho.
Old 07-30-2018, 11:37 PM
Doesn't matter who made the generator.....
Old 07-30-2018, 11:42 PM
There is a member here who makes them also. We usually recommend him. Very good quality, nearly half the price.
https://www.onlycubcadets.net/forum/...ad.php?t=34457
Old 07-31-2018, 07:15 AM
Default Voltage regulator
Thanks again - I will ha e to remember Mike’s harnesses for my next Cub project.
Tags
polarity, voltage regulator, wiring
