Old 08-07-2018, 02:04 PM
cooperino's Avatar
My truck doesn't use a screw style, spin kick bendix. Neither will his. They don't need lubricated.
Ok. so you remove your NEWLY installed starters every couple months and lube them?? I have never once put lube or oil on any new starter of this kind. An S/G starter with a lube hole I have.
Old 08-07-2018, 02:06 PM
cooperino's Avatar
It will fix it. If it doesn't, you likely need a new battery. A little oil is a cheap thing to try first though.
Yes, Power problem as I have stated already.. A little oil might make it so your weak battery has an easier time temporally.
Old 08-07-2018, 02:19 PM
I'm sorry you aren't familiar with this issue Coop. You learned something new today.
Even if it does need a new battery, it doesn't take this may posts to figure it out.
Old 08-07-2018, 02:36 PM
cooperino's Avatar
Post number 4 said it all. I can't force the OP to work on his tractor. And by the way.... It's not fixed yet
And you did not answer the question.
Old 08-07-2018, 02:48 PM
cooperino's Avatar
Originally Posted by moses2 View Post
Yes, the battery tender which indicates a full charge by a green light. Trying to start it at that moment will spin the gear, but not throw the bendix. And yes, 3 starters. I replaced the original starter for this reason, and then got about 2 years out of that. These last two have been just a couple months. It's intermittent. I can be running the tractor for a period of time, shut it off for a few minutes and go to start it and have the same thing happen. Most times a couple clicks with the key and it starts. Turns the engine over like it should. How would I check for a short?
So,, you didnt have to lube the starter for 2 years. Then you replaced with 3 new ones within a few months... And lube is the issue according to Jon.. Well, Lube away
Old 08-07-2018, 03:30 PM
yettrbomb yettrbomb is offline
I agree with J, lube the bendix shaft. Do it to dads 1811 about every 2 years. For whatever reason it seems to hang up (or in this case, in) just about the time for spring oil and filter change/blower removal.
Old 08-07-2018, 03:35 PM
cooperino's Avatar
Every 2 years I can see.. 3 new starters within a few months tho?
Old 08-07-2018, 05:34 PM
moses2 moses2 is offline
Ok, here it is- I got my meter out and rang out the battery cables. I looked at the harness as it went under the cowling against the frame, and while some of the electrical tape was worn so I could see the wires going to the head lights, is was just the electrical tape that showed any real wear. The battery before I started this was at 12.52 volts, and the tractor had been sitting since Sunday. I pulled the starter, got a small screwdriver and some 3 in 1 oil. I put a couple drops on the front of the shaft, advanced the gear with the screw driver, and put a couple drops on the back side of the shaft. I worked the gear back and forth with the screw driver. Reassembled. The tractor fired up first try. I got out my meter again and measured 13.92 volts while running. I shut off and re started the tractor 5 times. If the problem returns in a short amount of time, I'll say this wasn't the solution. but....until then. Thank you all for your help and kind advice helping me keep my tractor running.
Old 08-07-2018, 06:33 PM
How about this test.....???
What is your voltage, as measured with a VOM or DVM, at the starter (Large Terminal to ground).....while the engine is turning over..??
Old 08-07-2018, 07:21 PM
I will try to get that measure tomorrow.
