Old 10-13-2018, 11:47 AM
cnewell cnewell is offline
Default Cub Cadet 100 Wiring to Switch HELP
Hello,
I’m in need of some help with wiring up a new ignition switch on my Cub 100. The previous owner had a 5 prong switch even though for the 100 there are only two wires that go to the switch (light green and black). I bought a new 3 prong switch part# IH-60736-C3 that has terminals marked BAT, IGN and ST. Can someone help confirm which terminal the light green wire should go to and which terminal the black wire should go to? Im assuming one of the green terminals is not required or is that incorrect thinking?
If it’s helpful my Cub has the push button start combo with key ignition.
Thanks,
Clint
Old 10-13-2018, 12:17 PM
jbrewer's Avatar
jbrewer jbrewer is offline
OK... you could replace that key switch with just a toggle switch since you have the push button start.
Find two connections that are OFF (open) when the key is "off" and connected when it's in the ON position of the switch.
If you have an ohm meter, it's a 30 sec check. It's probably BAT and Ignition. You got this!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-13-2018, 12:41 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
https://www.onlycubcadets.net/forum/showthread.php?t=35
here is the wiring diagram which is found in the "Technical Section"
Queen Of The Quietlines!
Old 10-13-2018, 02:18 PM
cooperino's Avatar
I am in the middle of refurbishing my 100. Someone had a toggle switch for the Ignition switch. I really want a on/off key for mine. So I will be using something like my 8n switch. Its a 2 wire like this
https://www.ebay.com/itm/Key-Switch-...WlSZ:rk:1:pf:0
You could use the three wire switch by using the battery terminal and ignition terminal.
Old 10-13-2018, 02:44 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by cnewell View Post
Hello,
Thanks,
Clint
You don't need the ST lug. Connect the black and green to BAT and IGN. It dosn't matter which wire goes on which lug.
Old 10-13-2018, 04:17 PM
jbrewer's Avatar
Correct... it's just a single pole single throw switch
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 10-13-2018, 05:21 PM
Default 100 Wiring/switch
Awesome, thank you all for the quick replies and sharing your expertise! I’ll leave the ST alone and hook up the black and green wires to BAT and IGN as recommended.
Old 10-17-2018, 07:08 PM
jbrewer's Avatar
Should have worked fine for you...
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
