Old 12-29-2018, 02:38 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default Nutserts
Hey Roland,
I have used nutserts many times and they work just fine.
They may require a rivet gun type of install, but they are not too expensive.
I have done the larger ones using a bolt and a screw for compression and in some cases used a washer on the back side for taking up any gap.
https://www.amazon.com/s/ref=nb_sb_n...32+nutsert+kit
I have used standard DE grease such as this for many years with no issues:
https://www.walmart.com/ip/CRC-Diele...gaAq_nEALw_wcB
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 12-29-2018, 05:09 PM
sorner's Avatar
sorner sorner is offline
I’m sorry.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 12-29-2018, 11:34 PM
sawdustdad's Avatar
I use Penetrox A on electrical connections in the panel. Mostly for aluminum to avoid oxidation, but I think it would be fine for the breakers. I believe the breakers come with some sort of grease on them already, at least most I've seen have it.
