Old 01-19-2019, 12:38 PM
ALANRUNFELDT's Avatar
ALANRUNFELDT ALANRUNFELDT is offline
Default Thanks for Wiring Diagram
i recently replaced my rusted out ignition switch, but it was so badly corroded that I could not figure out how it had been wired. With the help of the Cub 1450 Wiring Diagram posted on OCC, I was able to figure out which wire was which, where they came from and where they went, and where they connected to the switch. This made it possible to install the replacement switch ($10 from a local guy who has 30+ cubs in his yard) and fire up the tractor.
And now I am ready for the forecast snow storm - just in time...
But there was one more problem with the old Cub. After having sat out in the weather for too long, not only did the ignition switch rust away, but the fuel bowl float valve got stuck as well, so even though i could crank the engine and fire it using starter spray, it would not keep running until i found the stuck valve down in the fuel bowl.
Now the tractor is back in service and running fine. This tractor came with the property (3 1/2 acres) we bought in 2012 and had been purchased new by Old Ed back in the 1970s, so I sort of feel responsible for keeping it running just as long as humanly possible. This web site helps me to do just that. Thanks!
- Alan near Frenchtown, NJ
Old 01-20-2019, 12:03 PM
Gompers Gompers is offline
Welcome to OCC and glad the site could help you!
That tractor will last forever with basic maintenance like that. That generation of cub cadets were called "Quietlines" and they are pretty great aside from the motor mounts going bad. Really pretty bulletproof!
Tags
float valve, wiring diagram
