Anytime you hitch above the axle center line, one must
be careful not to do a wheel stand and cause personal injury.
I found this 2" receiver hitch. Hmmmm.....
https://www.xtrememotorworks.com/Par...Cub-Cadet.html I guess I can try the factory hole and a 2" ball and see if the jack can go low enough first.
1973 Cub Cadet 149 2023 John Deere X590 Farmall B sitting in relative's barn |
If not you can always use a pair of 2x6's under each tire to make up the shortfall...
I would get one of these, drill a 5/8" hole vertically and bolt it to your hitch plate. If you keep it tight against the front of the hitch when marking the hole, when you tighten it down it will not move. Use a grade 8 bolt. This also gives you two different heights.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
