Ok Guys need a bit of assistance here .......I'm looking to find the correct wiring schematic for my SGT. Any / all help will be greatly appreciated.
model 1872 model # 149720100 ser# 791249 trying to resolve an intermittent issue and to also have one in my binder for future reference. Thanks Much ! |
Check the e-mail address as listed in your profile.
Thank You Mr. Bedell !
However ....... how is it that the main wiring harness in my SGT that appears to be original has a number of GREEN wires that I cannot find on ANY schematic? I have a green wire with an eyelet on it ( I assume a ground) just hanging around down near the starter neighborhood that exits the main harness just below the tank outlet "area". Thanks ! |
Have you owned the Tractor since new...??
I have not , however there was one owner prior to me. A municipality , it was always serviced at the local dealer. If this harness is not original , someone did a bang up job replicating a factory harness.
Then someone modified the original harness. Follow the diagram I sent you and bring it back to where it should be.
Ron , check out these pics..... I don't believe that anyone has modified the original harness.
That wire bolts to the flywheel shroud.
Thank You Sir , I guessed that it was a ground , but always best to confirm.
OK still trying to find out why I have no power except at the battery !
Gotta start some where , so first things first. Please see attached pic of wiring schematic, note that I have circled the only 2 fuses shown. Where physically are these fuses located? I have one fuse holder in the dash to the left of the key switch (just replaced with new as original had shorted out, the apparent start of my electrical problems). I can't find the other that is shown. I am guessing that fuse "A" is the fuse in the dash , ? correct? I realize that the fuse for the lighting circuit doesn't affect the start circuit , but I'd like to know where it is. Thanks in advance ! |
