Old 09-14-2019, 09:59 PM
93Tim1440 93Tim1440 is offline
Default 2182 w/60" Haban
Went to mount my 60" Haban deck and one of the spring-loaded pins, nos. 28, 34 and 35 on the diagram is missing. The previous owner has replaced it with a bolt and two nuts.
Would anyone have these, the pin, the spring, and the roll pin or I would accept the entire plate no. 18 if someone had it available?
Old 09-15-2019, 07:39 AM
cooperino's Avatar
Originally Posted by 93Tim1440 View Post
Went to mount my 60" Haband deck and one of the spring-loaded pins, nos. 28, 34 and 35 on the diagram is missing. The previous owner has replaced it with a bolt and two nuts.
Is is possible that the part your looking for is part of a different sub assembly? Even obsolete parts are usually in drawing just NLA. McMaster's has a bunch of pins,springs, etc
Old 09-15-2019, 09:26 AM
Try the sponsors at the top of the page. Click on the links
Patton Acres
Cub Classics
Houtz
Cub Cadet Specialties
Last resort take the good one to a machine shop and have one made.
Old 09-15-2019, 11:43 AM
Originally Posted by cooperino View Post
Is is possible that the part your looking for is part of a different sub assembly? Even obsolete parts are usually in drawing just NLA. McMaster's has a bunch of pins, springs, etc
No, those three parts have their own separate part numbers.
HA-20308 (Pin)
HA-5681 (Spring)
HA-GM9416147 (Roll Pin)
Old 09-15-2019, 11:47 AM
Patton Acres
Cub Classics
Houtz
Thanks, Sam.
I'll start the search tomorrow.
Whoever moved my post for more exposure, thank you also. It never occured to me to start a new thread.
Old 09-15-2019, 12:47 PM
cooperino's Avatar
HA-20308 (Pin)
HA-5681 (Spring)
Ok. I misunderstood. I thought you were looking for part numbers
Old 09-15-2019, 01:10 PM
You are welcome.
Old 09-15-2019, 01:13 PM
Just a FYI, the early Haban decks just used a 3/4" round bar stock with a hair pin clip on each end. The bar went all the way across the hitch.
Old 09-15-2019, 02:52 PM
Pics of my deck.
Old 09-15-2019, 03:27 PM
Take the existing factory pin and the bolt out, and replace them with a solid rod with a couple holes drilled in it for a couple hair pins.
