Old 11-17-2019, 04:20 PM
Brandon966 Brandon966 is offline
Default 124 Hard Steering
My new to me 124 has gotten progressively worse steering since I purchased it a month ago. When I bought it, it didn’t have the easiest steering but was ok. It did have an issue where it does not want to turn to the right very far, that still exists.
I’ve used it a few times around the house and the steering is hard enough where I have to use two hands most of the time. Also it is on the sloppy side with a good bit of free play in the wheel.
I’ve seen the tips and tricks of greasing the box (which took allot of grease), and checking the steering components. Tie rod ends look new but there is certainly play in the system.
Any suggestions of where to start?
Old 11-17-2019, 05:40 PM
Remove components, clean, replace worn parts, (install upgrade kit!) re install. I did mine this past spring and have been nothing but happy with it. New tie rods etc too. It's in this post.
https://www.onlycubcadets.net/forum/...eering+rebuild
Old 11-17-2019, 06:13 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I was having a tough to turn steering problem earlier with my 125. It turned out to be the knuckle assembly. Dried grease was the culprit. Just adding grease didn't help as much as pulling the assemblies apart, clean out the dirt and dried grease, put back together and adding fresh grease. What a huge difference! Feels like I have power steering! And yes, as mentioned previously, examine the steering box and the ball joints!
Plow blade
#2 Cart
QA36 snowthower
Old 11-17-2019, 08:53 PM
Exactly the same with my 125. Cleaning and greasing made all the difference
