Old 05-16-2020, 11:32 AM
ctcub ctcub is offline
Default 125 hydro forward and reverse issue
Just picked up another 125 to use as backup. Having an issue with the Hydro.
The forward and reverse speeds vary. Sometimes I have lots of forward speed and very little reverse speed. Then at times I go from forward to reverse and it has plenty of reverse speed. I have adjusted the neutral position and it looks to be correct. Not sure whats next. It is usable as is but would like to get it where it needs to be. Thanks
Old 05-16-2020, 07:26 PM
Any idea on if the filter and fluid has been changed?
Up to 534 and counting...
Old 05-17-2020, 02:15 PM
Oil looks fresh but is down from fill hole about a half inch. Filter does not look like it has been changed in awhile. I intend to do that this week. Question will I lose any oil other than what is in the filter when I remove it? Thanks! Mark
Old 05-17-2020, 05:19 PM
Red Dave Red Dave is offline
You can whatever you want to, but I would not just change the filter without changing the oil too. One of the most beneficial things about changing the oil in a hydro is that you have to remove the rear plate to drain it. That gives you the opportunity to reach in there with rags and clean out all the sediment and general gunk that accumulates in the bottom of the differential. Make sure you have plenty of clean rags before you start the job. It can be pretty dirty in there if it hasn't been changed in awhile. If you don't clean it out, anything that might be in there will just move into your new clean filter right away.
It's a little more expense, you'll need a gasket and about 7 quarts of Hy-Tran, but it will be a far more satisfactory job when you are done.
That's what I would recommend.
Old 05-17-2020, 11:02 PM
While you are at it, check the relief valves to make sure they are actuating as they should. If not, some PB Blaster and manually work them out should loosen them up.
Old 05-18-2020, 06:20 PM
They look like they are working ok. One is a bit wet. Need to replace o-ring. On my list. Thanks.
Old 05-18-2020, 08:47 PM
You just don't "replace the "O" ring" you have then rebuilt, or replace then.
Old 05-19-2020, 10:10 AM
MrRazz MrRazz is offline
Check for slop in the linkage. That can cause a variation in speed. Also check your trunion. The end caps on the springs can get hung up instead of sliding if the trunion needs welding.
Quietline 1250
Old 05-19-2020, 10:23 AM
What is the Trunion? Excuse my lack of knowledge. I adjusted the cam plate so it has full travel in both directions. What is the spring above the cam plate that has the bracket running through it? Is that what you are talking about? Thanks for the help!
What does that entail?
Tags
hydrostatic
