Old 06-06-2020, 07:43 AM
mik125 mik125 is offline
George you make sense to me. Thanks.
Old 06-06-2020, 07:50 AM
take your time, think things out.
The guys here are most helpful when you get stuck.
You will be pleased at what you can accomplish.
Old 06-06-2020, 12:34 PM
Thanks again.
Old 06-06-2020, 04:06 PM
New gasket is on, even used a torque wrench (30lb) on the pump bolts.
Are there rubber mounts sandwhiched between the pump and and the transmission on those 4 bolts?
I thought I saw some as I pulled the pump apart but I must have imagined it because they disappeared when I went to reassemble.
Old 06-06-2020, 05:27 PM
I've not seen anything on those bolts and you don't have a transmission per say.
you have a hydro, you prolly mean the reservoir/differential housing.
do follow the manual adjusting your neutral setting on the bracket you had off that is attached to the hydro to diffy housing bolts.
be careful on starting so it don't lurch fwd/back, be prepared for it.
good idea to have rear wheels off the ground.
--------just a FYI
Old 06-07-2020, 03:12 PM
Yes it was creeping much more than usual aftrr i put it back together but i made it better, not perfect, with the adjustment.
Hardest part of the job was lining up the bolt hole in the chasis when putting it back together.
Thanks again.
