Old 06-22-2020, 03:02 PM
weiler1 weiler1 is offline
Question Uneven mowing
My front left wheel on my ZTR 1 is uneven with right wheel. My backyard is pretty uneven with a lot of holes. I have an acre of land and after mowing for a while I noticed it was mowing unevenly. I pulled it onto driveway and my front left wheel is off the ground, spinning free. What caused this and how do I fix it? Can I just loosen the bolt that it is attached to?
File Type: jpg D242BE9B-1329-4E21-AC76-58C3CE12C0D5.jpg (30.6 KB, 57 views)
Old 06-22-2020, 03:30 PM
First, welcome to OCC........
From here, it looks like the Front Axle is slightly bent upward on the LH side.
Old 06-22-2020, 03:41 PM
Exclamation Bent axle?
How can I repair it?
Old 06-22-2020, 03:48 PM
IN MY OPINION.........
There are several way to do this. As "one" suggestion. One could cut a slit in the front axle (Left of center) and push down until a straight edge shows no light through, then weld the slit shut.
There is always buy a new front axle too.
Old 06-22-2020, 05:33 PM
Not familiar with zero turns,
But does not the front axle pivot?
if so, possibly it is frozen??
or one of the rear tires not the same pressure as the other?
Old 06-22-2020, 06:20 PM
cooperino's Avatar
Much like a plow foot.. Cant you simply take bogey wheel out? apply washer under the one thats higher and reinstall?? Or is there not enough shaft remaining at top?
I would check opposite side rear tire pressure as well. I think front is fixed so low pressure on opposite rear tire would cause this as well
Old 06-22-2020, 08:09 PM
Hard to believe they would not built a front axle that pivot's, to conform to the ground, it's not a 3 wheeler.
But again, I've not worked on one.
Old 06-22-2020, 08:55 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Speaking for my Scag Turf Tiger. Tire pressure can change the mowing level. Yes the frames are rigid. I can put one front tire up on a ramp and clean the deck real easy.
2-1811's
1872
2072
Old 06-22-2020, 11:37 PM
cooperino's Avatar
Yeah.. none that ive owned or seen pivot.. All ridged . I think if it did pivot may be cut would be even worse based on how the decks hang
Old 06-23-2020, 06:23 AM
If that is the case, the mower is like a 4-legged stool,
there is virtually no surface where all four legs of a stool can simultaneously touch.
One will always not touch.
My rear finish mower is the same way,, it has four tires, and no flex.
virtually all the time, one of the tires is not touching,,
Normally you do not see the condition, as the gap is masked by the height of the grass.
BUT, when I drop the mower on the concrete in my shed, one of the four tires will not be touching the concrete.
On the ZT, equal air pressure in the rear tires is critical to level mowing.
Tags
front wheels, uneven cut
