Old 06-25-2020, 07:23 AM
sorner's Avatar
sorner sorner is offline
Originally Posted by TomRom View Post
sorner - please forgive me if this crosses a line, but I could not resist!
I came across this image while surfing the internet and could not help but notice a possible family resemblance. Could this be a long lost relative?
Oh, and good luck with the 122, one of my favorites!
No relation... haha
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 06-26-2020, 06:25 PM
sorner's Avatar
Originally Posted by MattC View Post
I did exactly this recently on a 104 with a buddy. You have to mix the front of a narrow frame mule drive with the rear section of a WF mule drive. The reason is so that the drive will clear the offset pulley on the deck. Worked out great for us, and cuts much better than the smoked 42" NF deck we removed.
I'm currently rebuilding a 50" deck for my 126 and will post pics if I ever finish it. Haha
So I attempted this today. I can’t get it to mount up. The back part of the hanger that goes up to the cross bar doesn’t fit because it has two pieces of metal welded on so it’s wider. So I thought I’d switch out the swivel part that has the forks that go to the front of the deck with the 122 one and now after an hours long struggle I got the deck mounted, but it won’t lift. At the highest point the deck is still on the ground. At the lowest it is pushing down on the deck, and that’s at about half way down. There isn’t much room to travel up and down.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 06-30-2020, 08:26 AM
MattC's Avatar
MattC MattC is offline
That's strange sorner. We didn't encounter this issue. I'll ask my buddy to take some pictures of his setup.
Current Fleet: 100, 126, 147, 128, 1450, 1650
Old 06-30-2020, 08:48 AM
MattC's Avatar
MattC's Avatar
My buddy did remind me that he had to grind the lever arm a bit to fit onto the cross bar.
Old 06-30-2020, 05:20 PM
sorner's Avatar
Thanks Matt, that lever arm is the issue. Grinding it would help.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-01-2020, 09:46 PM
sorner's Avatar
I ground about 1/2" into that arm, and now it fits and goes up and down pretty good. But now my belt doesn't fit, and neither does the one off the 128.. Both are too short. Did you have to use a different size belt?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-02-2020, 07:55 AM
MattC's Avatar
Hey Sorner,
He didn't, but who knows if his belt was the size cub listed in the first place. He bought the 104 recently, and is more of a Wheel Horse guy.
I'm a bit surprised, because the pulley should be more or less in the same spot. Should be easy enough to rectify though. Good luck and post some pics when you get it sorted.
Old 07-02-2020, 08:12 AM
sorner's Avatar
Thanks Matt. The pulley on the 44C is a little bigger around I think than the 48" deck. The belt probably only needs to be about 1-2" longer than what I have to fit right. I have three here, the one that came off the 128, and the one from the 122, and an extra one that came with the 122 that the guy wasn't sure if it was the deck or pto belt, and none of them fit.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-02-2020, 06:50 PM
sorner's Avatar
Some pictures of the tractor and my helpers.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
