There must be something very satisfying about vacuuming up leaves with an 1864--it shows in your smile. It's nice when you have good equipment that does what it's designed to do.
Thanks for sharing the pics--the setup looks great.
Stanton 1980 IH 782, Kohler M18 IH #1 Cart, original IH 42" Blade, modified to 50" and hydraulic 2015 XT2, Kawasaki 23 HP |
Even if you don't have an 1864, there'll be a smile on your face while vacuuming, vs raking!
Yes, it is very satisfying to use my 1864 (that was carefully restored and works like new) to do those jobs like mowing, hauling and sucking up leaves! I'm looking forward to going out tomorrow to do another "leaf session" before it rains again.
I have not experienced any clogging of the blower hose yet. I have a set of hi-lift blades on the 54" deck that I keep very sharp. I generally mow over the lawn (only when dry) at a slower rate when picking up leaves, compared to normal mowing speed. Hoping I don't have to suck up any wet leaves...that will surely clog the hose...
That's what I was thinking. Nice paint touch ups/mods too.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Looking good!
That think is a Cherry Bomb! Soft spot for 1864s tho, first love... you have a really nice looking setup. I bet it's works great!
Yep! The restoration on the 1864 was finished last May. It is "cherry" and a pleasure to use! Good as new...if not better than new with all the time I put into it!. The leaf vac is practically new...only used 2 or 3 times. Sucking up the grass and leaves was a pleasure this year!
![]() Here is a list of my equipment: 1864 - 54" deck, CC Mow 'n Vac; 1641 - 44" deck, 42" blade; 1641 - 45" blower, lawn roller; 1450 - 44" deck; JD 110 - 38" deck, 37" blower, 31 tiller, snow cab w/lots of LED lights, JD 10 cu ft cart, lawn sweeper; JD 4100 CUT - 410 loader, 60" deck, 4' tiller, 5' box scraper, 47" snow thrower, 54" blade, 25 gal. 3 point tank sprayer, R4 and turf tire sets; Husqvarna 21" SP mower/bagger, Billy Goat 12" sod cutter; Kees Power rake; Lesco 19" aerator; Troy-bilt "pony" rear tine tiller, plus Stihl weed wacker, chainsaw, blower...Boy, just thinking about it... that's a lot of stuff! I'm running out of room! Gotta sell some of it before too long...
Hey there 1864 brother, I solved the leaf problem a different way. I moved from one acre of woods to one acre without trees!
Hey there Rodster...nice rig! Smart move, getting out of the woods...guess you could say you put your 1864 out to pasture! She looks like a garage queen already!
Seriously though your 1864 looks great!
They are both great lookers guys!
