Old 11-16-2020, 12:13 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Default Bagger on the 1512
Finally got tired of dealing with the leaves from 3 huge oak tress in my yard. It was time for a bagger. I knew it would be a peice together project since finding a bagger that was intended for my cub would be near impossible. I wound up getting the bagger from a 2500 series, a 46 GT deck from a 1641 and had get to the discharge chute from cub. I had to build my own bagger mount which turned out better then i thought. The discharge chute from the deck is 8.25 inch while the 2500 serires upper chute is 7 inch, so had to make a "custom" connector. All turned out well and it works good. It does fill the bags up quick tho. I found if i run over all the leaves first with out bagging to chop them up the bagger will go longer between dumps.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 11-16-2020, 07:52 PM
Came out nice Ken.
Old 11-16-2020, 09:50 PM
I like it.
Small leaves take up less space than large ones. Enjoy.
Old 11-16-2020, 10:45 PM
Nice job Ken.
Old 11-16-2020, 11:10 PM
ken6x6's Avatar
Thanks guys.
Anyone know the difference between low lift and bagging blades as cub lists them?
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
