Old 11-22-2020, 05:39 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Are all the steering columns the same?
I need a steering column assembly for one of the rusty cubs. Did all of the IHC cubs use the same column/ross gear?
Thanks!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-22-2020, 06:53 PM
Short answer is............NO.
Basically they are, except..........for tube length.
Old 11-22-2020, 07:16 PM
jbrewer's Avatar
Thanks Roland, What versions were common to the 100? Narrow frames?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-22-2020, 09:49 PM
It depends on the model. I know that not all NF steering columns are the same. It does vary between the models. If you are looking for one to replace or match up with the 100, then I would imagine the 70 or 71 would probably be the best candidates, but you should still check tube lengths.
Old 11-22-2020, 09:54 PM
One from a 582, thru a 1711 will work and are the same height.
Up to 534 and counting...
Old 11-23-2020, 08:30 PM
The ones put in the quietlines and newer are longer than the older ones.
Old 11-25-2020, 07:53 PM
jbrewer's Avatar
Thank you all for the advice!
I may have to hunt for one
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-25-2020, 07:59 PM
Hunt here. 71, 72, 73, 102, 122, 123 any 82 series, and 100...
