Old 11-26-2020, 08:02 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Originally Posted by Cubcadet_107 View Post
I even got the 147 already too, just need the 126, 127, and 73.
I've seen a 126 and a 127 for sale recently, but it's just not the right time currently. Coming up on winter, so best save up some extra cash for spring and I can go buy another one then!
I'm doing the same thing with that series all I'm missing is the 126. I'm still looking. Good looking pair
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 11-26-2020, 08:05 PM
Cubcadet_107's Avatar
Originally Posted by Billy-O View Post
All those good looking cubs and not one ready for snow duty?
They do look good!
One of my Deere's has a blower, but it's no fun at all. Darn thing's variable speed can't work right, Gives ya 3 speed ranges instead of the 7 it's supposed to. One of those ranges is "not moving at all", then there's "slow", and lastly "meh". I had to add a helper spring to one of the belt tensioners, made it better but still the same 3 speeds. And one of the rear wheel spindles is worn bad, and the electrical system is butchered badly (push button start and a simple toggle switch for ignition) Not to mention that the blower drive belt is nearing its demise, and I don't have the piece that connects the blower to the lift lever. Don't get me started on how loud that blower is either. I'm scared to even try the mower deck. Heck, only good things on that machine are the Kohler K181 and Peerless transaxle, the 2 things NOT made by Deere!
Gosh, no wonder we all like Cubs so much, so many problems! Or maybe I just bought a bad machine... Sorry about my rant, it just felt good to let all my frustration with that machine out. Most of it is easily repairable, I'll get it done eventually. The only thing I'm clueless about, and the one thing I don't like, is the Variable speed system. I don't see any way to adjust it or anything to make it work properly, unless my drive belts are stretched. In that case, if I ever find replacements I gotta tear apart the whole thing, because in order to replace them the whole moving pulley assembly has to come out. Definitely not a simple task. No wonder I don't get frustrated with my Cubs, even with a permanent tunnel cover nothing is that hard to do. Heck, I can have the hydro off the 107 in like 30 minutes and depending on the task get it back on and ready to go within the next hour.
Oh well, this site isn't about JD, it's about Cubs, and I like it that way
I do very badly want a blade for the 106. Only issue is, they aren't very plentiful around here. There was a blower for sale a while back but it was set for a wide frame. I'll get one eventually, maybe next year
Edit: I went and read the repair manual for my JD and may have figured out that the reason it's variator won't work right is that the center portion of the 2 pulleys is stuck, and doesn't move side to side like it's supposed to. I will check that out tomorrow. Anyway, no more Deeres!! This is a Cub Website, why am I taking it off topic?
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 11-26-2020, 11:00 PM
IHCubCadet147's Avatar
They look good! My favorite series as well.
