Old 12-07-2020, 05:28 PM
Rodster Rodster is offline
The experiment worked great. Soaked the blades in a vinegar/water solution for a couple of days and a wire brush knocked the stuff off with ease.
Just a little super hard stuff remained around the mounting holes but a quick pass of the Scotch-Brite disc after these pictures cleaned it up perfect.
Now if I could only soak the whole deck!
Old 12-07-2020, 06:25 PM
Looks like you have mulching blades. They may not stay as clean a hi-vac blades.
Old 12-07-2020, 07:28 PM
Hmmmm
I thought they were hi-vac (lift) blades....
Old 12-08-2020, 07:00 AM
bugeye bugeye is offline
I sharpen the blades about twice a year. Mow about four acres of mostly uneven field grass. The blades are caked with grass/weed debris like the picture. I clamp the blades to a metal stand outside then hit them with a wire wheel on an angle grinder. Green deposits come off quickly. Then sharpen with an angle grinder.
I clean the deck underside at the end of the season and apply a bit of used oil to the surface.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 12-08-2020, 08:39 AM
Originally Posted by Rodster View Post
Hmmmm
I can't really tell from your pictures.
Old 12-08-2020, 11:29 AM
That's usually how I clean the blades, but thought I'd try the soaking experiment this time. If I have the time, I'll probably soak them again as they cleaned up much easier, quicker and cleaner then the scraping and wire wheel method.
I clean my deck about twice a year and haven't found anything that makes cleaning easier. At the end of the season, I clean it real good and apply a coat of paint. Might try POR-15 or I have some professional PPG DTM (Direct To Metal) paint this year. Maybe follow with a coat of RUST-OLEUM® NEVERWET?
Old 12-08-2020, 11:30 AM
Do you have any pictures of the two types of blades? I didn't think mulching blades were available for my deck?
Old 12-09-2020, 06:24 AM
brudder brudder is offline
You know what they say about opinions... but I would say those are hi-vac blades. I mow with them year round on my 46" deck because I think it gives a better cut even when I'm not bagging.
Old 12-09-2020, 11:53 AM
ironman's Avatar
ironman ironman is offline
I use vinegar all the time for cleaning rusted part, including blades. I don't get your reasoning for cutting it with water? It's not like vinegar's expensive or it's going to damage your blades. Please enlighten me.
Old 12-09-2020, 08:15 PM
I found a 'formula' online plus I wasn't looking to remove the rust, just prevent it while soaking.
Worked great.
