Old 05-26-2021, 06:24 PM
woodbuilderbob woodbuilderbob is offline
It won’t roll over. Just keeps cranking over but not starting
Old 05-26-2021, 08:22 PM
I don't know what you mean.
Old 05-26-2021, 09:00 PM
Probably got it flooded.
Can't believe you are still dinking around with this issue yet.
Old 05-26-2021, 09:03 PM
Sorry...the engine crank keeps turning but won’t start
Old 05-27-2021, 08:31 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Let go all the way back to when you first posted.....
You wrote: "Then I took off the air cleaner and put some fuel into the carb and it started fine."
Today, If you do that again, will it start? It it does, then you need to concentrate on a fuel delivery problem like Roland pointed out in the second post! Otherwise, you might have made a bigger mess chasing this no-start problem for the last couple months.
Plow blade
#2 Cart
QA36 snowthower
Old 05-27-2021, 09:19 AM
ironman's Avatar
ironman ironman is offline
Put a friggin' voltmeter or test light on the positive post of the coil.
Do you have voltage when you turn the key to the on position?
Do you have voltage when you turn the key to the start position?
If the answer to either or both questions is no, persue a keyswitch/electrical problem.
If the answer to both questions is yes, persue a fuel problem.
This ain't the Mars Rover we're workin' on!
Old 05-28-2021, 11:24 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
If it won’t even try to start on starting fluid, I would imagine it has to be an ignition problem of some kind, assuming you haven’t been inside the engine recently.
Old 05-29-2021, 06:50 AM
Pitch the dam starting fluid!!
Do you have compression when cranking?
I'll bet not.
Old 05-29-2021, 08:52 AM
jbrewer's Avatar
jbrewer jbrewer is offline
You need gas, air, compression and spark for this to run.
Do you get spark if you lay the plug on the head and crank it?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Tags
carburetor
