Old 05-29-2021, 10:54 AM
Frank1541 Frank1541 is offline
Default 1864 play in drive shaft
How much, if any play is acceptable in the drive shaft for an 1864. I get some play when I grab the drive shaft near the hydro coupling and move it from side to side. Is this normal or a problem? I think it needs to be looked at, but I wanted to check before I tear it apart. Removing the drive shaft is a pain in the butt.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 05-29-2021, 06:54 PM
Should not move side to side.
Old 05-29-2021, 07:59 PM
Is the shaft moving in the CV joint or is the adapter moving on the pump input shaft? I've seen a few adapters that the splines have worn and you get some movement.
Old 05-30-2021, 07:12 AM
I am pretty sure that the shaft is moving in the CV joint. I will know for sure tomorrow when I take it apart. Hopefully that is the case.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 05-31-2021, 05:52 PM
I spent the day working on the drive shaft. Definitely a worn CV joint. Luckily I had the parts laying around. Glad I caught it before it fell apart.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 05-31-2021, 06:21 PM
CubDieselFan's Avatar
Which parts were worn?
Old 06-02-2021, 03:21 PM
The drive couplings were worn. The drive hub and ball bearings were OK. Now I need to remember to grease the drive shaft more often.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
