Old 06-01-2021, 08:43 PM
Frank1541 Frank1541 is offline
Default Hydro Destroyed?
I figured that I might as well change the hydro fluid and filter while I was fixing the CV joint on my 1864. Got it all back together and moved it around the garage and everything seemed OK. No leaks etc.
I started it up to move it back into the garage. When I tried to go forward it made a nasty sound and it would not go forward, it would go backwards. Then I realized that it was spraying hydro fluid all over the place. I could not see anything obvious with the tunnel cover off. Maybe it is just a bad relief valve?
Has anyone seen something like this? Fortunately I have a spare. It should be a lot of fun cleaning up the driveway tomorrow.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 06-02-2021, 10:18 AM
V30crewcab V30crewcab is offline
I would wash it off and figure out where its coming from. might be a simple fix. did you double gasket the filter?
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 06-02-2021, 11:54 AM
The forward pressure relief valve failed completely. All the internal part are sitting in the hydro. Fluid was shooting out the top of the valve at high pressure. I was able to pull the valve without taking the fender off. I cannot see into the hydro to see where the parts went. Hopefully they did not cause more damage. I need to figure out if the valve was bad or did something cause it to fail. More to come.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 06-02-2021, 12:13 PM
RLause's Avatar
RLause RLause is offline
I had one do that and all the pieces were contained below the valve. I think you might be able to retrieve the parts with a skinny magnet. Good luck.
Richard
Old 06-02-2021, 02:10 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I wonder why that happened...??? Was the relief valve
previously rebuilt?
Plow blade
#2 Cart
QA36 snowthower
Old 06-02-2021, 04:17 PM
Thanks Richard. I made a magnetic retriever and got all the parts out. I put in a spare valve and fired it up. Seems OK so far.
The bad valve might have been a rebuilt one, but I am not sure.
Now I need to figure out the best way to clean the concrete that is stained from the hydro fluid?
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 06-02-2021, 09:35 PM
Ozcub's Avatar
Ozcub Ozcub is offline
I would start with a layer of Cat litter (clay type) to suck some of the oil up , then a detergent wash and finally a degreaser
Oz
Old 06-03-2021, 03:31 PM
You can pull the 2 plugs on the bottom of the pump, they are directly below the valves.
Old 06-06-2021, 09:03 AM
Sam Mac,
I realized that I could have just removed the bottom plug just as I was pulling the last part out with the magnet. I blame old age
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 06-06-2021, 01:06 PM
Oil dry and a hard wood block the sooner the better.
Go at it like you were an old scrub maid until the oil dry turns to dust and keep rubbing.
Sweep up the dust, spray w/brake parts cleaner or carb cleaner, hit with a wire brush, rub it in and repeat as needed.
