Old 07-12-2021, 07:49 PM
dutchcanuck dutchcanuck is offline
Default CC 1450 Tie Rod to Oil Pan Drain Plug
Anyone with a 1450 able to provide the normal clearance between the front end tie rod and the oil pan drain plug? With my recent acquisition it seems the tie rod has rubbed against the oil drain plug due to insufficient clearance. Motor mount issues? I’m a newbie to the CC world?
File Type: jpg B82E3231-EAEA-4F17-B9E4-5590CD6890D0.jpg (16.1 KB, 82 views)
Old 07-13-2021, 05:00 AM
Mounts must be shot and I'd bet the cradle rails are worn into the X member as well.
Aluminum pan is more than likely badly worn at the mounting bosses also and may be missing a bolt or two ore even 3!!
Common issues for the QL series.
Did you check for any of this before getting out your wallet??
Remove the engine and check for damage in those areas ASAP
Old 07-13-2021, 11:48 AM
It is possible that someone put the tie rod on upside down?
Up to 534 and counting...
Old 07-13-2021, 07:55 PM
esean esean is offline
An upside-down tie-rod will hit the axle and only let you turn the wheels half way. Don't ask me how I know this!
