Old 12-30-2021, 10:42 PM
CubbyRI CubbyRI is offline
Default 100 Throttle Cable seized again - options?
Ok I have about had it with this one. My cub sits outside and the choke and throttle cables are again stuck. Throttle cable broke off up at the lever.
Are there stainless cables I can attach to the CC throttle lever, or can these be covered in heat shrink or other tubing to keep the lube inside and the water outside?
Ideas welcome!
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 12-31-2021, 03:41 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Try searching push and pull cables in the marine industry....for boats. They do make stainless.
This is an example but I don't know if this fits:
https://www.napaonline.com/en/p/BK_7...ng_dcoe_google
Otherwise I would think about a storage shed or garage for the whole tractor, not just the cables.
Plow blade
#2 Cart
QA36 snowthower
Old 12-31-2021, 04:37 PM
what he said....
Old 12-31-2021, 04:43 PM
K thanks, I will look at marine products. be nice if I could marry a marine cable to the OEM throttle lever and that should be doable.
Old 01-01-2022, 01:51 PM
Gary C Gary C is offline
Have you ever tried using "chain and cable spray" ? I believe it's made by " Lubriplate". It works great on motorcycle cables and chains. I also used it for my hood release cable for the car. Speedometer cable .
Old 01-01-2022, 02:26 PM
thanks gary I will add that to my spray cans shelf...
Old 01-01-2022, 04:55 PM
Farmall450's Avatar
When they get tight I just soak them with a similar product, and they always release.
Old 01-01-2022, 05:14 PM
yeah I hit it with PB Blaster but didnt wait long enough and snapped the throttle cable end at the throttle itself.
I figured there might be generic stainless cable since I will have to try to reattach something anyway. I want to save the throttle control.
Old 01-02-2022, 08:23 AM
j elliff's Avatar
j elliff j elliff is offline
I have the same frozen/seized cable issue on a 100 myself. I am planning on using an ultrasonic cleaner and then high pressure air. Lastly I’ll soak it down internally with motorcycle chain lube
livin the cub life
Old 01-02-2022, 12:01 PM
all that will work, as I have done that several times. but, it will stick again.
If I had covered the tractor with a tarp (loosely to keep the moisture from accumulating) it wouldnt have stuck at all.
Im still for getting a marine or stainless cable and never have the issue no matter what
