Old 01-24-2022, 11:01 AM
Gary C Gary C is offline
When I resealed the cylinders on my Case 646, I got the seals from "Grizzley seals" they are in Canada and Washington State. The hoses I measured and ordered from "Discount Hydraulics" , ( same place I got the hoses for my plow on the 1872) they were exactly to the size of what I ordered.
Old 01-24-2022, 12:04 PM
MFP is who I use for "O" rings and "V" packing in hydraulic work.
They pretty much have what I've needed on the farm.
Now you can't just call them up and say I need a thingy, because mine is leaking.
You do need to know what you need, be it a O ring, back up rings lip seal, vee packing, glands etc. ect. and of course, the size.
They are a big supplier of the industrial and oil businesses world wide.
https://www.mfpseals.com/
Old 01-26-2022, 11:32 PM
ChristopherCT ChristopherCT is offline
Yes- I agree! In late spring, all fluids and filters will be changed, and all the grease points (wow there are a lot, and most are dry and needing new zerks probably). It might need one or 2 master brake cylinders. Then I figure I will drive and dig a bunch. If it holds up well, then some basic painting begins. But this machine will never be a show piece and I have NO intention of making it look "new". Like you said, its battle scars and wear patterns- its got character all its own.
Old 01-26-2022, 11:36 PM
Thank you Gary! I will need some hoses and seals. I may NOT have the time to do the cylinder rebuilding myself, and I might drop them off at a hydraulics specialty place. I'm not sure yet.
Old 01-26-2022, 11:38 PM
Thank you George! With a good caliper and the make and model number, I hope I will be able to size and replace things.
Old 01-27-2022, 09:03 AM
You will learn alot about hoses and seals, but that is the fun of it.
Tractor supply has a line is lesser expensive hoses, but most times one has to use adapters for the ends, as TSC hoses have pipe thread fittings, but some will fit, you just have to compare.
A lot of your pins and bushings will prolly be worn, but most times they will work just fine digging holes and covering them back up
Those industrial machines were built to be worked day in and day out, every day for years.
Old 03-01-2022, 05:27 PM
powerpooch's Avatar
powerpooch powerpooch is offline
I happened to notice you said Discount Hydraulics, which if you mean is www.discounthydraulichose.com , then they are actually Hydraulax Products Inc. in Philadelphia, PA. I found them when looking up a specific Ford TLB hydraulic fitting, and they seem to be one of the few places that carry it. I suspect you might be able to get a better price going to their store than online.
